Model 51012. tried flushing with vinegar
SOURCE: vinegar flush
You should not have to flush unless the code LC comes up. but here is the flushing diagram.
SOURCE: how to get detergent to feed into Greenworks 1700 psi washer
In addition to the comment above regarding the need to use a low pressure (soap) tip, there's a chance the tanks or the hoses from the tanks to the valve and/or from the valve to the pump is plugged with dried detergent. The easiest way to clean out the hoses, unless you can see the plug with the detergent bottle removed, is to remove the top cover and pull all the hoses and flush them out. Removing the cover is not too bad. There are several recessed screws underneath, including a couple above the wheels that requires removing the wheels and axle.
SOURCE: How to add oil to my greenworks 1700 pressure washer model#gws293
if electric , you don't add oil and if petrol , put in through the filler plug
