From your local Agricultural Extension Agent or other knowledgeable persons.
SHAKE WELL BEFORE USING.
Partially fill the spray tank/container with water. Add the desired amount of LIQUI-COP and continue filling the tank/container. If applied with other products, add LIQUI-COP last. Agitate the tank during mixing and application until tank is empty. A plastic or metal stirring stick should provide adequate agitation. Observe all cautions and limitations on labeling of all products used in mixtures. Start with clean equipment. Equipment should be flushed well with water after use.
APPLICATION: Fruits and Nuts: Mix specified rate in 1 gallon of water and apply 3 gallons of mixed solution to a small tree or bush, 6 gallons of mixed solution to a medium size tree, or 9 gallons of mixed solution to a large tree. Thoroughly spray tree to point of runoff, including upper and lower surfaces of foliage. Do not overspray. Do not mix more spray solution than needed. Vegetables: Mix specified rate in 1 gallon of water and apply 2 gallons of mixed solution per 1,000 sq. ft. (1 gallon of mixed solution per 500 sq. ft.) Miscellaneous: For herbs: Mix specified rate in 1 gallon of water and apply 2 gallons of mixed solution per 1,000 sq. ft. (1/2 gallon of mixed solution per 250 sq. ft.) For trees: Mix specified rate in 1 gallon of water and apply 3 gallons of mixed solution to a small tree, 6 gallons of mixed solution to a medium size tree, or 9 gallons of mixed solution to a large tree. Thoroughly spray tree to point of runoff, including upper
NOTE: This product may be reactive on metal and masonry surfaces such as galvanized roofing. AVOID contact with metal surfaces. Do not spray on cars, houses, lawn furniture, etc.
and lower surfaces of foliage. Do not overspray. Do not mix more spray solution than needed. I also have directions for specific nuts, fruits and vegetable.
