Video Cameras Logo
T
Thembeka Posted on Jun 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi.please help how do i take pictureswith my camcorder.how do i change to colour?
Tony Parsons
Level 3:
  • Video Cameras Master 6,405 Answers
  • Posted on Jun 09, 2019
Tony Parsons
Level 3:
Answers
6405
Questions
Helped
1652063
Points
20272
This information will be in the manual. Briefly, aim the camcorder at the subject, and press the record button. Not knowing the make of the equipment, we cannot help with the second part of your query.
1helpful
Sony CCD V800 change colour to black and white The hi8 lose the colour to black and white when playing
Ether the unit is very dirty and needs to be cleaned as far as the heads go or you got a bad head inside. This will be determined by a camera shop most likely its just dirty and needs its heads cleaned. A HI 8 still is a magnetic tape and thus dirty or dust can get in the recoder head and thus obscure the color or recording. I would be on the safe side here and have a camera shop take a look is you best bet.
Thanks and please do be considerate and leave feedback and ratings for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
TV won't show external device in colour
sounds like your using rca jacks yellow red white you need to use componet green blue red then red and white for audio
HI, MY JVC GR-DX95EK DIGITAL VIDEO CAMERA IS RCORDIND SOUNDS ONLY AND HAS COLOURED STRIPES INSTEAD OF BEING ABLE TO SEE WHAT U WANTTO VIDEO, OR WATCH THROUGH LENS OR SCREEN, HELP PLEASE!
found web site for jvc in uk they have recall on camcorder as its a fault is to do with the camcorder showing "lens cap still on" they are repairing it free.
Jul 17, 2008 • Cameras
Sony HandyCam SR10(NTSC) working with my Philips 21PT2443 model
Hi Pawan, Now I am in the same situation as you were. I am planning to buy one sony camcorder from US. But it supports only NTSC. But My TV is philips 29PT7322, User Manual says it supports, NTSC and PAL colour systems. But I am not sure it works or not. Can you please help me with your experience. Thanks in advance, Kinod
Sony DCR-HC32 display problem
replace the flexwire asap, it's hard to fix and you need pro help to do it. flexwire has a possibility of shortcircuiting the unit, the reason your small viewer started to show problem. Here in the philippines i'm not replacing it with an exact replacement, instead i'm replacing it with the more strong wires or cables such as the one used in laptop computers, still, you need profix to do it. [:0)
2answers
Colour problem when recording with Panasonic NV-MX500
Hi, I recently had he same problem, you need to have the unit repaired, it is a small but extremely expensive part that has broken. If my recollection serves me right, it's the colour sensor. There are three that combine the colours to give natural colour. My repairer stated that vibration caused the problems to my camera. Good luck.
Mini dv digital camcorder
This is a failed ccd (device that makes the image) problem. If you ship it to jvc by October, they are still repairing this problem at no cost because of a batch production. Go to jvcservice.com for support info. Good luck, magic seadog
No display on lcd screen
Hai First check other functions, If all the functions ok then LCD ribbon cable may be defective, replace LCD ribbon cable. best of luck udupi Prathiksha Electronics Bangalore
Belkin Hi-Speed USB 2.0 DVD Creator + Sony TRV65E Hi-8 Camcorder
Here is the solution from another group. I hope this helps. Let me know (It sounds like Belkin & M$ have some bugs to deal with) JC QUOTED TEXT There is a God!!!!!!!!!!!! I have just spent HOURS with a USB 2.0 DVD Creator trying to get it to work - the Ulead software that came with it was a piece of crap that I eventually after several tries got to install & then crashed every time I tried to open it - just like many of the posts I have found - could not solve the problem so gave up. I have spent considerable time combing forums trying to find the solution (I hate to be beaten!) - was close to giving up when I found this post - did not solve the problem but set me on the right track, & with a bit (lot) of luck - i am home!!! Here's what I did - the problem IS Windows Movie Maker defaulting back to NSTC. In WMM Set the format to PAL in "Options" - from memory this is in the Tools menu - sorry, I am in the middle of capturing video, so cannot access the menus to check. The only thing you then have to do was advised courtesy of an email reply from Belkin: "In windows movie maker, click on capture from video device and then choose the device and then there should be a configure button. You will need to change the video standard to PAL and then it should capture in colour" Sounds simple enought, but - PROBLEM - you try to do this but you cannot apply the change & it does not take - so you still have capture but no colour. Here is where luck stepped in - I decided I had spent too long trying to make this work so started surfing for alternate capture software. I came across several possibilites & downloaded them. Just picked randomly on one & installed it - beginner's luck!! - about time i got a break! When the software finished installing the program prompted me to install something else that it needed to run, which I did - don't ask me what it was - i was so blown away when i got WMM working that it has completely escaped me! Anyway, I installed the software (& the other required file), opened the software (which was a trial version) & attempted to capture - same problem - sound but no colour - then I recalled about changing to PAL, so went into the setup, changed the video to PAL - & bingo, all OK. I then (for some reason - madness maybe) went back into WMM, configured for PAL as advised, & double bingo - it works!!! - as soon as I clicked on PAL I could see colour video in the preview screen. Actually, I think what made me go back into WMM was that SuperVideoCapture looks & feels VERY similar to WMM . I have since uninstalled the trial software program, & am capturing in WMM with no problems - & in colour. The last piece of the puzzle (after the pain I have gone thru I couldn't bring you this far & not give you the final piece of the puzzle) - the software was SuperVideoCapture & the trial version can be downloaded at download.com - hope this gets around & ends the many headaches that people are having with getting the belkin hardware to work
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
