Error code SC670 shows up on my board
It’s an over load of information by the file.
Here is the actual code: SC670 mistake Engine Response.
It’s always a good idea to ask for a fix along with a question about an error code...
so what’s going on is no response from the BCU at power on; which means when the main power is turned on or the machine starts warming up from energy-saving mode, the controller does not receive a command signal from the BCU. So that could mean a
• Loose connection
• Defective controller
• Defective BCU
You can try these things:
1. Turn the main switch off and on.
2. Check the connection between the
BCU and controller.
3. Replace the controller.
4. Replace the BCU.
After replacing the BCU or controller, remove the NVRAM on the old board and put it on the new one.
If you have not worked on these units before you may need the help of a shop.
