Re: How do install a retention lever in a lot 2000 ride...
Husqvarna Craftsman AYP OEM Riding Mower Deck Mount ... (Important) Craftsman LT2000 Lawn Tractor Lift Lever Grip ... How to Install a Craftsman Mower Deck.
It is possible that the neutral lever (free wheeling lever) has been actuated by pulling the lever out during the repair. For normal operation the lever should be pushed in.
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
all the riding mowers free wheel rods are on the back of the mower below the fender with a locking mechanism, zero turns are either under the seat where the hydraulic pumps are or under the mower but above the deck there's 2 rods on every zero turn. not all the riding mowers have the roll rod some just have neutral and the machine rolls, check your brakes under the back transmission just jiggle the brake and it should unloosen and free roll I hope at least some of this information helps you if not now then in the future
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
If your blades won't engage when you raise the lever to engage them AND
that lever moves freely without the normally expected resistance, then
you've lost the cotter pin that connects the lever rod to the mower deck
assembly. Very easy fix! Using the mower deck raise/lower lever, lower
the mower deck to "down" position. Now, lay on your side along the right
side of the mower and look up (use a flashlight) under the mower at the
top of the mower deck while moving the blade engagement lever "up"
(which pushes the connected rod down). At the end of the rod, you will
see a hole where the mower deck and rod connect. Align the hole at the
end of the rod with the matching "pin" on the mower deck (you'll see it)
and insert a new cotter pin to secure them together. Use a nail if you
don't have a cotter pin. Voila! you are done. The blade engagement lever
will now engage/disengage your mower blades successfully. Just remember
that mower deck must be down, or lowered, before you engage the blades!
First look under the tractor and check that the mower belt is installed and not obstructed or broken. Second, check the linkage from your engagement lever on the tractor to the PTO on the mower deck.
yes it can be fix.but it might cost you alot of money.i will try to help you.let me know. want parts you need.i need a pic.i have lots parts.let me know.ok
