Refrigerator stopped cooling. Did that once before and I did this:. I unplugged it and plugged it back in 27 hours later to melt any ice buildup on the compressor. It worked before, about a year ago, but doesn't seem to work now. A little help would be nice.
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
SOURCE: Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
SOURCE: GE side by side refrigerator has stopped working...
sound to me that the unit may be stuck in defrost. look for the time clock and or if it is a newer unit check your condenser coil it may be dirty. the unit may also have a leak on the refrigeration side of it.
SOURCE: SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle. Call a tech repairman
SOURCE: Refrigerator not cooling
We had a similar problem - it was the compressor start device. Ordered a new one from repairclinic.com, and it works great now. The old start device rattled when we shook it. We opened it up and found lots of burnt little bits. Check to see if your compressor kicks on & off a lot. Ours would run only about 10-15 seconds, then go off for a minute or two - then back on for a few seconds. If that is happening, it could be the start device. Hope this helps.
