SOURCE: cb feedback though external am/fm speakers
Hi Big OX,
Terrible problem. I know what your going though. Route your AM/FM Antenna wire, and Speaker wires separate from the CD Antenna cable and power supply wires. If you can, twist the speaker wires. If the Speaker wires are run along side the CB Antenna wire for a short distance, you will pickup feedback. If you much have the Antenna wire get near the speaker wires, have the antenna wire cross the speaker wire at a 90 degree angle. Try not to run the antenna wire in paralell with the speaker wires. Good luck
SOURCE: owners manual for connex 4600 turbo
to cut down on noise i would hook it directly to the battery. make sure there is a fuse in the power cord first.
Robert
Please rate this solution thanks
SOURCE: need Radio wiring diagram 2004 chevy silverado 2500hd (oem plug)
Left Front Speaker(+)
TAN
; Size:
Left Front Speaker(-)
GRAY
; Size:
Right Front Speaker(+)
L GREEN
; Size:
Right Front Speaker(-)
D GREEN
; Size:
Left Rear Speaker(+)
BROWN
; Size:
Left Rear Speaker(-)
YELLOW
; Size:
Right Rear Speaker(+)
BLUE
; Size:
Right Rear Speaker(-)
LT BLUE
Yellow -ignition
Orange-Constant +12 volts
Black - ground
If you need more info, please ask.
A rating is appreciated.
SOURCE: i need a wiring diagram for my 1995 chevy
HERE IS THE RADIO DIAGRAM.
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
SOURCE: REPLACEABLE? dash, radio, climate control dash lights, 96 C-1500
yes they are they take the miniture bulbs to replace them you must remove the four screws holding them on from the back side 5/16ths to get them off then slide out and allow to drop down follow wires and twist sockets out to remoce aocket and replace bulbs, ther are 4 bulbs in the dash console for ac and heat.
