Watches Logo
Ronald B Posted on Jun 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Watch is frozen face 3 fasten watch to get heart rate data
Joy R
Level 2:
Habit-Forming:
  • Expert 72 Answers
  • Posted on Jun 08, 2019
Joy R
Expert
Level 2:
Habit-Forming:
Answers
72
Questions
Helped
12649
Points
115
This question is unclear. What type of watch are you talking about and what are you trying to do?
5 Related Answers
Anonymous
  • 1902 Answers
  • Posted on May 22, 2009
SOURCE: Inaccurate Measurements of heart rate
Replace the battery. Then make sure that it is placed on the proper artery that it is supposed to be on. If your heart rate was 210 you would be in the hospital with a heart attack. And also the only person I know with a heart rate of 90 when running is Lance Armstrong. Your heart rate should be about 120 to 135 and it will just around in those areas but should never go higher
Anonymous
  • 2501 Answers
  • Posted on Jan 27, 2010
SOURCE: Sportline S7 HRM watch users guide?
To get a manual for your monitor, go to "sportline.com",
Select "products" and then "see products" in heart rate monitors.
Go through the list of models to find yours and then click on "learn more".
Details of the monitor will be shown and you then click on the tab marked "manual".
Download your manual.
Testimonial: "thanks :)"
Anonymous
  • Posted on Feb 25, 2010
SOURCE: I just got a sportline solo 915 heart rate watch.
For Sportline 915 all you have to do to turn on the heart rate feature is to press the reset button on the lowe right and put your finger on the meatl part. A heart will appear on the top right of the screen indicating that the feature is on.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Apr 20, 2010
SOURCE: how do you turn on the heart rate monitor on a
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Anonymous
  • Posted on Dec 30, 2010
SOURCE: Sportline 915 heart rate watch 2nd mode questions
the number is for your age, the F or M is for female or male. this will give a more accurate percentage for your heartrate
I just received a brand new Garmin FR 60 with HRM monitor strap and ANT USB from Amazon. I followed the directions to use the strap[wet the electrodes, strap it over my chest, with the Garmin logo facing...
navigate using mode button to enter into watch's menu tree for settings/ sport/ run/ heart rate and turn on the heart rate monitor to hopefully detect and scan for the garmin ant+ protocol heart rate strap!
Sep 22, 2011 • Watches
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
How do I reset the chronograph? Once I start it I can't find a way to reset it.
In heart rate mode, click reset to go to Calorie burned mode. In that mode press and HOLD reset button and this should reset all lap,calorie data. etc
6helpful
The display is frozen and I can't get the watch to reset. I was beginning exercising and it is frozen on this screen.
If there are no reactions to any buttons, reset the
wrist unit by pressing all the buttons
simultaneously for two seconds. All other settings
except time and date will be saved.
manual is here
5helpful
Battery in a Polar F7 heart rate monitor
Hello
You can change the battery in your polar f7 if the battery is worn out.
1. Insert the tip of a pen knife into the lifting point and lifting the back up. The back of the watch is only pressed into place and will come off easily this way.
2. Grab the small clip that is extending across the surface of the battery with a pair of tweezers. Slide the tweezers toward the end that hooks down into the watch. Pull the hook end of the clip out of the watch and remove the clip from the battery
3. Match the old battery with a new one at any electronic store. The store will be able to read the writing imprinted on the battery to make sure that you get the correct battery type for your heart monitor.
4. Press the new battery into the watch making sure that the writing on the battery is facing up.
5. Press the holding clip back into place. Handle the clip with tweezers only, since it is very thin and can be bent or lost easily. Once it is in place, press the back of the watch on.
GOODLUCK
11helpful
How to turn on the heart rate mode of solo 915 sport line watch?
Please make sure you are in time mode. Now hold your bottom right button in for 2-3 seconds. You will see a heart pop up over the seconds. Now you will be able to take your heart rate.
157helpful
3answers
I just got a sportline solo 915 heart rate watch. When i put my finger on the metal part of the face it is supposed to measure the hr, but is says "HR Off". I can't figure out how to turn it on. Any ideas?
The resin straps on either side of my heart
Where can I take my son's Marcel Drucker to get the crystal face that was broken in pieces?
1helpful
2answers
Sportcraft Heart Rate Monitor Watch
On mine you press and hold the ST/FWD button.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
