My action replay ds leaves the start screen but then just goes white even before it reaches the main menu.i tried blowing on it it and it still does the same thing
Hello dijanilaplac,
There can be many problems with your Action Replay DS. Try taking the Action Replay out of your Nintendo DS Lite Console, and look at the part those goes into the DS. Make sure nothing is bent, or missing. If something is, it might mean you may have to have it repaired, or replaced. Also keep in mind that sometimes Action Replays can be sensetive, so don't move it around while playing, or it may cause your DS to freeze up.
If you just bought this Action Replay recently, it should have been supplied with a CD to insert into your computer. You should install Action Replay onto your computer. When you have been brought to the main Action Replay Code Manager, find your USB and Action Replay plug in. Plug the small end into the top of the Action Replay cartridge, and the USB into the computer. Now a New Hardware wizard should have popped up on your computer.
When prompt, select, "Install from specific location.", then click next. Then select Search from CD-ROM. Sometimes it may sound different, just select the one that says something about searching from a CD-ROM. After this has completed, reset your Action Replay.
If the problem persists, feel free to contact me, for questions, or replies.
Nate,
