Database ad-hoc operator line
For a poor line
1 Related Answer
maxcarson
max carson
  • 7627 Answers
  • Posted on Dec 15, 2012
SOURCE: why does connecting to an ad-hoc network disconnect the shared mobile broadband connection?
You can be connected to two signals at one time, if I understand your statement. My question is, why is your laptop automatically connecting to a Ad-Hoc network? Your wireless adapter Intel Wireless 3945A/B/G,settings should be scrutinized. Perhaps this will help:http://www.intel.com/p/en_US/support/highlights/wireless/pro3945abg
Why does connecting to an ad-hoc network disconnect the shared mobile broadband connection?
tip
Set up a computer-to-computer (ad hoc) network
An ad hoc network is a temporary connection between computers and devices used for a specific purpose, such as sharing documents during a meeting or playing multiple-player computer games. You can also temporarily share an Internet connection with other people on your ad hoc network, so those people don’t have to set up their own Internet connections. Ad hoc networks can only be wireless, so you must have a wireless network adapter installed in your computer to set up or join an ad hoc network.
Click to open Connect to a Network.
Click Set up a connection or network.
Click Set up an ad hoc (computer-to-computer) network, click Next, and then follow the steps in the wizard.
Notes
If one or more of the networked computers is joined to a domain, you need to have a user account on that computer to see and access shared items on it.
If the networked computers are not joined to a domain, but you want to require people to have a user account on your computer for access to shared items, turn on password protected sharing in Network and Sharing Center.
To turn on password protected sharing
Click to open Network and Sharing Center.
Under Sharing and Discovery, if password protected sharing is off, click the arrow button to expand the section, click Turn on password protected sharing, and then click Apply. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
An ad hoc network is automatically deleted after all users disconnect from the network or when the person who set up the network disconnects and goes out of range of the other users of the network, unless you choose to make it a permanent network when you create it.
If you share your Internet connection, Internet connection sharing (ICS) will be disabled if you disconnect from the ad hoc network, you create a new ad hoc network without disconnecting from the old ad hoc network for which you enabled ICS, or you log off and then log back on (without disconnecting from the ad hoc network).
If you set up an ad hoc network and share your Internet connection, and then someone logs on to the same computer by using Fast User Switching, the Internet connection will still be shared, even if you didn't intend to share it with that person.
I hope you all found this information useful and helpful.
Phillip
on Jul 31, 2010 • Computers & Internet
How do i transfer files using win 7 ad hoc?
setting up a ad hoc connection is the most simple solution to to transferring files from one computer to another directly.
to set up ad hoc in windows 7
Open network and sharing centre from your control panel. Click Set up a new connection or network and choose set up a new ad hoc connection. Follow the instuctions in the wizard to set up the network sucessfully. Use the other computer to connect to the network and share files at your will...
HP Photosmart c6380 wireless printer works fine, but windows xp does not recognize the scanner
  • First, we need to create the Ad hoc network that will provide wireless connection between your computer and printer. On the right hand portion of the Taskbar, you can right-click the wireless icon and choose "View Available Wireless Networks". Or you can double click the wireless icon, then click "View Wireless Networks". It is also accessible from the Control Panel. Either way, the same window as shown in step 2 will pop-up.
  • 2
  • setup-xp-via-ad-hoc-1.2-120x120.jpg View Wireless Networks The Wireless Network Connection window shows you all the wireless networks in range including the network where you are connected. If you have many neighbors with wireless networks, it will all show up. Click "Change advanced settings" and it will bring up the Wireless Network Connection Properties window. Choose the "Wireless Networks" tab and at the bottom click "Advanced" button.
  • 3 setup-xp-via-ad-hoc-1.3-120x120.jpg Wireless Networks Properties From the Advanced option window, choose "ad hoc" networks only. This is just to simplify the process. You should also bring this back to original setting after you are done connecting via Ad hoc. You may choose to skip this step if you wish and you should still be able to make the connection without a problem.
  • 4 setup-xp-via-ad-hoc-1.4-120x120.jpg Create the ad hoc network Click the "Add" button and type in a name for your Ad hoc network. Make it more intuitive so you can easily recognize your own network just in case there are other Ad hoc in range. Check off the automatic key and enter a 5 or 10 digit network key. This is the same key that you will input at the printer later. Click OK and then OK again. You are now connected to the Ad hoc network. You are half way through.
  • 5 setup-xp-via-ad-hoc-1.5-120x120.jpg ad hoc network Make sure the printer is ON as well as the wireless radio button. On the printer control panel, press the setup button to access the menu. Go to Wireless Menu and press OK. Press the arrow to go to Setup Wizard and press OK so the printer will automatically search for wireless networks in range. From the list of networks, find the SSID or Ad hoc name that you created and press OK and type in the network key using the alphanumeric keypad on the printer. The printer should confirm the connection in less than a minute. That's it! Try to print a test page to make sure everything is working properly.
  • 0helpful
    I can't get the internet sharing to work. i had installed and configure the wireless router, Linksys WRTG45 connected to a desktop pc running win7. internet sharing is enabled on the modem. now we're using...
    If you are using the wireless router then you will not use the Ad-hoc mode.
    You aloso don't need to share the internet on the modem.
    make sure that if you conecnt the computer directly to the modem, it goes on line.
    If it is on line then you can connect the modem to the router and computer to the router.
    open the setup page and change the settings of the router.
    once ytou setup the router then you should be able to go on line on all the computer.
    You just need to connect to the network on other computers.
    Click Here for more information about the routers and network
    On my PSP I can't play with him
    On the left side of your PSP, there is a switch
    This is the WLAN switch. Move it up to enable or down to disable it.
    If thats not the problem, you may need to change your settings.
    • On the home screen (the place were you first turn on your psp without a disk), go to settings.
    • select "Network Settings"
    • then "AD Hoc Mode"
    • Select "automatic" for the channel and save.
    If that doesn't work, your game may not be compatible with Ad-Hoc. Look for games that have Ad-hoc on the back of the case.
    k24674
    ADMIN Andrew
    ADMIN Andrew
