Question about Radio Communications
I have 2 BT S2 communicators and cannot get them paired to each other, can you help with this?
3 Suggested Answers
SOURCE:
SOURCE: is there anyway to get a bluetooth phone and bt
I have on occasion been able to get my NVM 4070 to connect with my phone. I have tested several different phones with this GPS. I noticed that if you are using a smartphone or pda it has trouble connecting. However, if you try and connect a basic phone, like a Motorola Razr, it has no problem.Overall it is a frustrating process that involves quite a bit of superstitious behavior, on my part, to get the devices to connect. Try restarting both of them.
Once you actually get them to connect, good luck. Like I said, I am able to connect mine, but usually once I leave my car, I have to start the pairing process all over again.
Posted on Aug 13, 2009
casouzaj
  • 1118 Answers
SOURCE: not able to pair my bt-03a with my android device
Have you already tried to put your headset in pairing (discoverable) mode first? Anyway, in order to do it, starting with it turned off, press and hold the 'Play' button for some 7 seconds, until the indicator light is alternately lit in blue and red. It is in pairing mode now. Then, withing a couple of minutes, on your phone, go to 'Menu > Settings > Wireless & network > Bluetooth'. If the bluetooth radio is not turned on, turn it on. Then, tap 'Scan for devices'. After a little while, your headset should appear on the phone' screen. Tap over it to make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is succesful, your headset should enter the stand-by mode. An indication that a heaset is connected should appear on your phone too. If your phone indicates that only phone calls are available, tap and hold over it, until a context menu comes up, and select 'media', in order to make streamed music ffrom your phone sound on the headset.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Posted on Feb 14, 2012
What is the PIN code of CMA 3549 Craig bluetooth speaker so I will paired it with my laptop
if they ask for a code, it is always 4 zeros 0000 or 1234.
this is a different model, but see, it states.
When the external BT player searched the unit, our model number "CMA3581" will appear on the display of the external Bluetooth device.Pairing code "0000" or "1234" may need to enter.
Videos as well
craig bluetooth speaker cma3594 pairing Google Search
Jul 29, 2018 | Radio Communications
Isb23b won't pair. No blue light no matter how long I hold the "pair" button down.
What are you trying to pair to? That device might need to have the speaker added to a list of pairing devices. With my smart phone (and a different device than yours), I have to go to bluetooth, tap "More", then power up the BT device and add the device to the phone. It's always found after that.
Apr 06, 2018 | Radio Communications
How do you pair EB30 to PC
on the bt of the pc then search then EB30 when you see it then you can pair
Sep 07, 2017 | Radio Communications
AKG K 830 BT
Possibly the transmitter is not working or it needs pairing again.
Jun 23, 2017 | AKG K830 BT Bluetooth Headset
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
Password to blackberry 9000 bluetooth is not 0000, is it possible that it is not compatable with my HUAWEI phone?
Arlene,
Password for BT are set by us. and should be the same on both the BT connecting devices. When you want to pair with another BT device it will ask for a password. Give 0 or 00 or 000 or 0000 or and number upto four digits. and the same number has to be given on the other device too within the time frame. So please do that. Both the devices should connect and communicate.
If this helps, may I request for a 4 thumbs rating for answering a question free.
Sep 25, 2010 | Cell Phones
Bluetooth pairing code for Intempo BT-01
The pairing code is 0000. Turn off your BT-01 then back on again. The blue light flashes quickly. Only during that time can you pair with it. Good luck, Andy W
Apr 30, 2009 | Audio Players & Recorders
Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
Jun 03, 2008 | Radio Communications
Radio Communications Logo
24 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
