I cannot remember if it came with an adaptor to charge it...or if charges with just a cable...i do not want to damage it
SOURCE: Forfex trimmer FX766 won't charge
Angehair,
It is most likely the battery, don't even try to open the case if you don't know what you are doing, Forfex will not replace the batteries in these small trimmers as they state it is too labor intensive, I am working on obtaining batteries for these units.
They have to be soldered in.
SOURCE: Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
SOURCE: cannot pick up Ip address
try this it has worked for me many times
http://www.howtofixanything.co.uk/howto-269.html
SOURCE: Will not charge or turn on using USB cable.
Two things.
HTC phones will not charge from the USB port unless you have ActiveSync on an XP or Mobile Device Manager on a Vista PC loaded.
Second, if the phone has been stored for a very long time, 1 year if initially charged, 1/2 year if not, the the battery self discharges to a point the USB port PC Sync software doesn't know the phone is connected. You must jump start a charge on the battery by either and HTC AC charger, a generic AC/USB charger will not work, or you can apply a +5 VDC voltage to the power terminal, marked + and - on the battery case, on the two outside terminals I believe. This 5VDC must be current limited for safety. The Red and Black lead inside a standard USB cable will supply current limited +5 volts at 100MA. Chop off a standard USB cable, their cheap and break out expose the Red and Black leads. While connected to the PC USB port, hold the Red lead to the + battery terminal and the Black to the (-), or other outside terminal, of about 30 seconds to a minute.
Now when you plug the phone to the PC with a good USB, the Amber light on the phone to indicate Charging, may not come on for a while, 5 minutes or so, but it will eventually. If it does not, jump the battery again for a longer period of time.
An AC charger for the 3125 are fairly inexpensive. $7 or so, on ebay with shipping. This may be the way to go. Consider getting one with a new battery. They are sold this way sometimes and sometimes for little more that the charger alone.
SOURCE: changing trimmer heads on Conair Beard Trimmer - Model GMT188
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
