SOURCE: Dark streaks on copies from Xerox XC356 copier.
Replace the Drum Unit, Do you know how to rebuilt this unit, if not you can get an after market product, The Drum unit release is in the Middle of the Copiers you will see a door , open the door, then ONLY , and i do mean ONLY, touch the "Green" release lever for the drum take it out and replace it or rebuilt it f you now how, if this does solve it, which i am certain it will but, if it doesn't something is wrong with the fusing unit and needs to be dismantled, wish i could give you our contact info however, been informed not too so sorry. rules of fixya.com
SOURCE: Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
SOURCE: xerox m15i copier guide broken
This sounds like the paper path guide that sends the copy by the drum modual and then to the fuser.
If the walls are stained yellow, they the "vains" plastic guides are broken and will cause paper jams. Also after the paper has been fed out of the fuser modual there are other plastic guides that might appear to be yellow in stains. these tips often break and will cause constant jams.
The door guide has to be replaces and the vertical transport may need replacing as well. You would need to get part numbers for this specific model and someone who knows how to dissasemble this machine.
End result, you may need to call Xerox for assistance.
Good luck.
SOURCE: Xerox 3001 Copier. I installed new toner and the
Also I would wait until it stops first, then installed the paper, wait until it feeds through then see if you have the sa problem.
When new toner installs I always recommend to customers to wait for the cycle to complete ,then try it again. See if tht helps
SOURCE: I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
