Karcher Pressure Washer with Honda GCV160 engine will not start. Looks like I might not have gotten all of the fuel out at the end of last year and I'm thinking it could be something in the fuel system. Any ideas where to start in diagnosing and fixing?
Hello
You should siphon out all the old gas you can. Replace with new gas. Check that the spark plug is good and the air filter is clean. Spray some carb cleaner in the carburetor.. Also, you should check the oil level and change the oil if it is black. If it tries to start after you spray the carb cleaner in but won't keep going then you know the carburetor needs a good cleaning
remove spark plug after attempting start up, if wet , it is ignition problem, if dry, not enough or no fuel comming in
