You can easily install Linksys router without installation CD>
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Check this link to install linksys router manually. Linksys router setup Easy steps
Alternatively, you can enter http://192.168.2.1 into your browser and it will take you to a log-in box. The default password is left blank. Then just go through the set up.
1. you either know your password or have it written down. 2. You will have to load the installation CD and re-install the routers files to the computer to reset the user name and the password.\ 3. You will have to go to the manufacturer to load any updates for firmware for your particular router unit after re-installation. Take note of the password/user name use choose and write it down and store it.
It says that your internet service provider settings was not configured on router....
you can login to router manually by hardwiring any computer to wired port of router and by typing 192.168.2.1 in any web browser....
if your ISP is cable, then you need to do change the connection type to dynamic, and you need to do a mac clone, then turn off both modem and router...and turn on both, the status will change to connected....
in this case you ll never need the cd to be installed on your computer....
You can set up your router manually, without the CD. Make sure that your computer is able to go online directly through the modem. If your computer is able to go online through the modem, that means the modem is working fine. You will need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
are you trying to set up the router.
You don't need CD or DVD .
If you connect the computer to the modem, does it work ?
if that works then the modem is working. Now connect the modem and computer to the router. open the set up page of the router. change the settings of the router according to the ISP.
Click Here for more information about router set up
You do not need the CD that came with the router to configure it. To do it manually open your browser and type http://192.168.1.1into the address field. That should take you to the routers log onwindow and by default the user is left blank (some routers the user isadmin) and the password is admin. If you changed the password to therouter when you set it up before use that password. That will take youinto the router's set up so you can set up your router. Hope I Helped!
-- who is your internet service provider -- what is the operating system of your computer? -- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer. Step 2: reset the router while power on then Unplug the router’s power cable. Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds. Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable. Step 5: Plug in the router's power cable once the modem’s lights appear stable. Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code for 1 free technical support.
