SOURCE: majestic filter queen canister vacuum cleaner
It will work again if you press the reset button which is the little (really little) button right on the back of the part that suctions.
SOURCE: vacuum shuts off
if you want to fix this problem gently pry up the air flow control knob and look down at the plastic hose connected below the control valve. insert a small screwdriver and push off the hose from the valve. this disconnects the bag full indicator but will let the vacuum operate normally at full vacuum. you will change the bag when suction gets low. this will save you at least $100 repair bill.
SOURCE: SEBO vacuum cleaner
Take the hose off and see if the light is still on or is it off. If it is off, then there is a clog in the hose. While the hose is off, drop something thru it and see if it comes out the other end. Press the retaining clip and the hose will disconnect. Separate the power head from the handle unit to make sure there is no clog by the brush roll. If it is still on then probably the computer controller, part # 5740ER has a problem. It is located in the power head.
SOURCE: riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
