Question about Rowenta Irons
Rowenta iron dw8194 iron goes into auto shutoff light flashing moving iron side to side does not correct it
SOURCE:
SOURCE: Rowenta iron manual needed
does not heat but indicator light is on.
Rowenta steam Iron Model DE-871
Posted on Dec 26, 2008
wizzard8955
  • 18 Answers
SOURCE: Rowenta DM880 Auto shutoff - Shuts off too frequently
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Posted on Mar 06, 2009
  • 32 Answers
SOURCE: DM865 Rowenta Steam Iron auto-off indicator light
It sounds like a break in the wire, re-wire plug and take about a inch of length off the cable. if the fault is on the iron side it will need taking to a repair shop.
If helpful please tick box
Posted on Sep 03, 2009
heatman101
  • 43501 Answers
SOURCE: Rowenta SM700 Iron auto shut off. I do not get
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
tbreeze47
  • 3083 Answers
SOURCE: which colored wires bypass the
The component that will most likely turn off the iron will be a thermister- usually a round, coin-shaped device that opens up when the iron gets to a certain temperature. This is the part you should jumper if you want to disable this function.
If you can't locate it easily, we can only take an educated guess at the wiring, without the schematic diagram to identify them. We can assume red to be the hot wire, black to be the ground, and blue could be the output of the thermister. Without seeing it, I can't be sure.
If you're going to jumper any of the wires, you can try to jumper red to blue, or blue to black, but NOT red to black Any of these combinations coud result in the breaker tripping, so use caution and don't contact the device while powering it up.
Very few people work on irons, since they're generally considered to be "throwaway" items, but someone may be able to give you a more definitive answer.
Good luck, though, and hope this helps.
Posted on Feb 08, 2011
ROWENTA DW1050 STEAM IRON
it may be okay when it cools down.
Reviews on Rowenta are not good. :>(
https://www.consumeraffairs.com/homeowners/rowenta.html
Mar 15, 2017 | Rowenta Irons
IRon heats standing but the light goes out when I set it horizontal to iron a garment. I think the cord is needing replacement but need advice.
If the iron is not moved while it is plugged
in, an internal safety switch will turn it off.
- It will turn off in 8 minutes if left vertically or
in 30 seconds if left on its soleplate or tipped
over. A red flashing light indicates that the
auto-off has been activated.
The above information is from the Rowenta DX1700 Owner's Manual. I think most, if not all Rowenta irons have the "auto off" safety feature. If your iron is going off before the 30 seconds idle time, the sensor may be defective. If you are letting it sit on the sole plate longer than 30 seconds, you may just need to work faster. ;-)
Jun 11, 2011 | Rowenta Irons
Rowenta DZ9080 iron yellow light flashes but iron doesn't get hot
it is possible that there is a loss in contact in the iron you will need a local repairs man to do that for you
Apr 27, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Iron won't heat up!!!
A lot of rowenta irons have a safety or auto shutoff built in them that fails. The only way I have found to fix them is to disassemble it and permanently connect the switch then it works fine, just does not auto shut off.
Jan 14, 2009 | Rowenta Power Duo Iron
Jan 06, 2009 | Rowenta Professional Luxe DM880 Iron
My rowenta effective will not heat up.
Dec 15, 2008 | Rowenta DG5030 Iron
Irons Logo
27 people viewed this question
Top Rowenta Irons Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
