SOURCE: couldn't make any calls
You might try unplugging the base AND removing the batteries from the handset for 30 minutes. Then reinsert the batteries, place the handset in the cradle in the base, and then plug the base back in. This might allow the handset and the base to re-sync with each other.
SOURCE: Pushed pause. Added garment. Washer will not start again.
possible you have not held "start" button down for the required 5 sedonds to restart cycle??
SOURCE: The back of the seat of my 2003 G35 moves forward
this is not uncommon and the test is very simple. The seat motor often fails in this vehicle and the simplest test is this: (1)raise the front of the seat as much as possible, (2)tap on the motor housing while holding the seat slide button (seat motor you need is the one easiest to reach in the front/bottom of the seat). If this resolves your problem what you need is a seat motor. Unfortunately these are often only available with a complete seat base system, so if this is the resolution you may want to search salvage yards, this piece can be easily replaced by itself.
SOURCE: Volume won't go up
CAMBIALE EL IC02 EEPROM 24C02 O EL 24C04 Y TE GARANTIZO QUE SALDRAS DE ESE PROBLEMA...
