The ok button is working on all other functions now you just get the > flashing next to whatever wattage or time you choose and will not recognise you touching ok and turn on the microwave. even if you just touch on button the shortcut to automatic 1000w for 30seconds won't engage. the program flashes up on readout but doesnt start. any ideas done factory resets and the rest but nothing. the rest of it works to grill and so on. model num KME761000B thinking the magnetron? how do i check or where do i look etc. or as new shall i just call retailer?
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Microwave Buttons Not Working
The cycling of your electricity probably didn't hurt it.
Chances are moisture or grease has gotten into the controls. That can ruin the keypad.
The way to prevent that is to be sure you have the microwave's hood vent exhaust fan running whenever you are cooking on the stove top.
If you (or someone you know) might want to replace the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: GE Spacesaver Microwave touchpad
You almost certainly have a bad membrane keypad.
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can find
model number here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
very helpful when troubleshooting, testing, and locating
components.
have us
do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for
some GE models, the membrane keypad is not
available as a separate part, so you would have to order the control
panel frame assembly which comes with a new keypad.
In this case, you simply
move your circuit board into the new frame. That is a simple do-it-yourself
job.
Either way, we can let
you know what your options and costs would be and send you other
helpful info.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
We're
We're happy
to help you. Once we have all your information and
offer a final solution, we'd appreciate your
William E. Miller, AS-EET
[email protected]
Microwave Oven Control Panel Repair Nationwide
SOURCE: kenmore elite microwave touch screen stopped working
My microwave stop workin all a sudden it wont come on at all Ive tried changing plugs outlets dat didnt wrk so any suggestions please
