Lands Phones Logo
M
Meowmeow Posted on Jun 06, 2019
How do I transfer the phonebook from my old uniden phones to my new one? New one is d3098, old one is 15 years old- I tried to register a handset from the old one to the new base but it doesn't work.
T Tatro
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 20 Answers
  • Posted on Jun 19, 2019
T Tatro
Contributor
Level 1:
Greenhorn:
Cheetah:
Answers
20
Questions
0
Helped
4555
Points
38
Unfortunately, you can't transfer from the old to the new. There is no data transfer port (usb) and you will have to manually enter your phone numbers into the new phone.
5 Related Answers
Anonymous
  • Posted on Dec 12, 2007
SOURCE: VT 2461 Won't let me register new handset
jimmackey
were you ever able to register the additional handset? I have the same problem with 4 handsets, one broke and I bought 2 new vt2420 handsets. The unit wont register handset #3 (the one that broke). Would love to know if you were able to resolve the issue?
Anonymous
  • Posted on Apr 13, 2008
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Anonymous
  • Posted on Mar 05, 2009
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Anonymous
  • Posted on Jun 27, 2009
SOURCE: How to remove Uniden handset from base
The brillian people at Uniden don't feel it necessary to provide this type information in their manuals. You have to trial and error to find it, but what can you do. All you have to do to reset the base unit itself is to unplug the power, then while holding down the delete key, plug it back in. Hold the delete button down until you hear a beep, which indicates it has reset. Now you can readd handsets and they will start at 1.
Anonymous
  • Posted on Oct 09, 2009
SOURCE: ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Do you have one I can get at or view Thank you
If you're requesting the manual, I believe you can find it here:
http://www.manualslib.com/manual/334463/Uniden-Tru9565-2.html
Uniden TRU9565 2 User Manual
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
2answers
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
2helpful
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
4helpful
How do i copy a phone book for the Uniden DECT1560 cordless phone
Kathy,
This should do the trick!
Copying Phonebook Entries to Another Handset:
You can transfer one phonebook entry at a time or all phonebook entries at once.
1) With the phone in standby, press the address book icon.
2) To copy one entry, find the phonebook entry you want to copy, press Menu /Select , and then select Copy.
To copy all entries, press Menu /Select and then select Copy All.
3) Move the cursor to select the handset which you want to transfer the entries to and then press Menu /Select .
If you select Copy All, Are you sure? appears on the display screen. Move the cursor to select Yes, and then
4) The phonebook entries will be transferred to the designated handset. During the copy process, the receiving handset shows Receiving and the ID of the sending handset.
5) When the transfer is completed, Done! appears on the handset.
Notes: • The handsets must be currently connected to the same base.
• If the handset you want to transfer to already has seventy entries in its phonebook, you will hear a beep and Not enough memory in receiving unit appears on the display.
• If the selected handset is out of range or data transfer is cancelled, Unavailable appears in the display, Phonebook listings will not be transferred.
Have Fun!!
1helpful
2answers
Regarding connecting old and new phone of same brand
1. Remove battery
2helpful
I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
16helpful
2answers
Deregister lost or broken phones
Some tricks from a helpful Uniden rep:
holding down end+# keys at the same time on the phone for about 10 secs (you will hear a beep) will deregister the handset. If you have a dead handset and want to deregister it from the base, you have to reset the base. unplug the phoneline and power. hold down the "delete message" key, plug power back in. about 10 secs later, you will hear a long beep (theres a short beep upon powerup as well). At this point all handsets are deregistred and you will have to reregister them with the end+# trick. this way when #1 handset is dead, you can make a working one #1 and get the broken one fixed emotion-1.gif
BTW, this is a woot warranty, not uniden warranty. however the uniden rep gave me the number to the people who refurb (rox0rz!) these. I'll post an update when I finally get ahold of them (and the number if its actually helpful)
Transfer phonebook to new base
looks like a have the same problem and need to complete clear of the eprom. can you pls post instructions on how you did it?
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
