The service manual for your model should be here:
http://www.microwavedisplay.com/blmv169_glmv169_plmvz169gcb_sm.pdf
You can find helpful Frigidaire parts diagrams and get parts at affordable prices for most models from The Pros by entering your model number here:
http://tinyurl.com/gv383
Www.repairclinic.com will show the breakdown and replacement instructions and will carry the parts needed.
SOURCE: Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
SOURCE: Microwave light bulb out
This is simple, and "FixYa" technical staff has clearly not looked at our model.
Take off the vent across the top (three long screws) to expose a single screw over the keypad.
Remove the single screw, and the whole keypad consile will lift up and off, likely hanging by a plastic tab/support on the bottom.
Now you can twist the light bulb plug to remove it from the support structure, change the bulb, and replace all that you've done.
Simple.
SOURCE: changing the interior lightbulb of Maytag
I have a belling combi microwave, the covection oven works well but the microwave oven has stopped heating the food up and also the defrost isn't working ? Any tips or does it need repairing and wat are the costs?
SOURCE: HOW TO CHANGE VIKING MICROWAVE LIGHTBULB VMOS200
The Viking VMOS200 is essentially a rebranded Sharp R-530E.
One or both of these service manuals should cover disassembly and location of the bulb:
http://www.microwavedisplay.com/r530ekt_r530est_r530ewt_sm.pdf
http://www.microwavedisplay.com/r530es_sm.pdf
SOURCE: My frigidaire GLMV169 manufactured in
Hello there:
If your microwave oven doesn't seem to work at all, check these:
Fuses
Door switch
Fuses
Usually,
when your microwave oven doesn't work it all, the internal fuse
(thermal fuse) is blown. This fuse protects both you and the oven. When
it blows, you need to have a qualified appliance repair technician
replace it.
Door switch
If
the fuse isn't the problem, check the door hooks and the door-release
button. When these are broken, the door switch doesn't activate, so the
oven can't work.
Good Evening Gary, thank you for your post!
From the information you have provided you need to replace the lightbulb inside of your Frigidaire microwave. I have researched your microwave and you are unable to disassemble your microwave in order to replace the lightbulb. In order to provide you with a proper resolution I would suggest seeking assistance from a professional technician for repairs. This will help you avoid unnecessary part purchases or personal injury. -Matt
