SOURCE: fan runs all the time
The inside fan has to run all the time. It turns off it will not keep things cold. Not the fan outside in the air it shoulc cycle with the compressor.
SOURCE: Replacing temperature control on a True beverage cooler
Remove the doors, then the evaporator cover. Just be careful.
SOURCE: I have a beverage air kegerator that seems to work
as a general rule,coolers have the fans run 24/7. Freezers will have the fans shut off during the defrost cycle. If unit maintain temp., I'd not be concerned by it.
SOURCE: beverage air model UR30G, not cold, fan still running
check the thermostat for proper setting, evap could be frozen up, the condenser fan could not be running, unit could be low on freon. start check some items and let me know.
