SOURCE: XL1800 still works fine but makes a lot of noise while on.
It may be the stirrer in the ceiling area.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: DOWNDRAFT FAN MAKES LOAD NOISE
open your cabniet up under the unit you will have to disconnect the venting in this will give you access to the blower section also make sure the filter is not hitting it inside they usally install a screen to prevent this but maybe yours is missing
SOURCE: LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
SOURCE: AC make loud noise on power off.
Is this a wndow unit or central air system? if this is a window unit , your problem is it only needs cleanning (dirt dbber nest-- trash around the back blades-- or the unt is twisted and rubbing the fan shroud. Last but not least, the slinger ring around the back blades (a ring around the end of the blades thats picks up water in the bottom of the unit and sling it on the coils to help cool the hot gases....Thank-you Thank you Thank you very much!
SOURCE: acer m5100 desktop fan is making noise
Hi:
Often, just dust can make fans noisy. You can unplug everything, take the side cover off of your tower, and blow it out with a can of the air duster you can buy at a computer store, paying close attention to the fans. If you are not comfortable with this, a local shop should be able to clean it up for you for not a lot of cash, and if a fan is really bad, they could identify which one it is for you too.
