Question about Duravit Home
Duravit toilet is beeping - Duravit Home
SOURCE:
stefano-61
  • 69 Answers
SOURCE: How do i get the top off of my duravit toilet??
try to check if there is any screw on the side of pulling knob...try to pull it and chek around it...good luck!
best rgds Stefano
Posted on Jan 05, 2009
SOURCE: maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Posted on Apr 09, 2009
SOURCE: my duravit toilet keeps running
I too have had this problem. No matter how i change the settings ..sooner or later the toilet starts to flow continually getting worse and worse. I have had plummers and friends etc see if they can make it stop and it is no better. I am very disapointed with it and will never ever buy Duravit again. I tried contacting them for help and got nowhere. Bad design. Waste of money.. I should have stuck with the old ball-**** system at B&Q.
Posted on Nov 03, 2009
Obertelli
  • 3006 Answers
SOURCE: Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
Posted on May 29, 2010
  • 5 Answers
SOURCE: cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Posted on Jul 02, 2010
Duravit toilet cistern fills slowly
make sure the toilet shut off is all the way on (if there is one) replace filler valve and should fill quite quickly.
Oct 08, 2014 | Duravit Duraplus, Two-Piece Toilet -...
My duravit toilet was hung too low and I'm trying to find a solution that doesn't require opening the wall
If you raise the toilet you will have to raise the plumbing so you have little choice.
Nov 05, 2013 | Duravit Home
How do I replace a toilet seat on duravit happy D toilet
I think our toilet is a Duravit.
Close the seat and the lid then have a look at the back of the hinges. If you can see a small hole in the back of the hinge there will be a grub screw in the hole and you can undo it with an allen key (not sure what size - you'll have to try a couple)
May 21, 2012 | Duravit 0910100005 Happy D Toilet Cistern ...
The hinges of Duravit toilet cover seat 006331 are broken. Where can I get replacements?
I have not been able to find a "tribeca" on the Duravit website but on the site of one of their parts distributors I found the Duravit Toilet Seat DUR 006331000. Is this your model? Starck 3
On the Duravit website this product looks very similar but not the same number.
I was not able to find replacement hinges for this model sold separately. You might consider using their Find a Retailer feature to find an outlet close to you where you might make inquiries or order hinges and/or a new lid.
Jan 17, 2011 | Duravit Tribeca US-Type Elongated Toilet...
Does anyone know where to get hold of a manual for installing a toilet from Duravit, please? Specifically it is the Duraplus 022901. With many thanks, Fran.
Information on your product can be found here along with measurements for installation. However there does not seem to be detailed installation instructions.
http://www.duravit.com/products/series/duraplus/toilets/toilet-close-coupled--022901_toilets_91994_useo6q3rng.html#
Suggest you review the following series of videos which provides detailed instructions on toilet removal and replacement.
Trust this is helpful.
Jan 04, 2011 | Duravit Duraplus, Two-Piece Toilet -...
Have a Duravit Starck 3 2-piece toilet 2105010000 Hinges that hold the seat and cover are broken. Where are these hinges available?
Unfortunately you won't find a universal replacement part to work with this seat which you would commonly find at your local hardware store. I've looked through the Durovit site and could not find a parts catalog. Try using the find retailer option on the manufacturers site and if there isn't a retailer in your area contact the manufacturer directly to see if they supply parts for their seats. I'm guessing they don't and you would likely have to purchase a new seat.
http://www.duravit.com/service/find-a-retailer-useo6suuk8.html
Duravit USA, Inc.
2205 Northmont Parkway
Suite 200
Duluth, GA 30096
Phone +1 770 931 3575
Toll free: 888 387 2848
Fax +1 770 931 8454
Toll free: 888 387 2843
info@usa.duravit.com
Aug 02, 2010 | Duravit 0063810000 Stark 3 Toilet Seat and...
How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
Nov 14, 2009 | Duravit Darling Wall Mounted Toilet White
My duravit toilet keeps running
Jan 31, 2009 | Duravit 001422.00.00 Vario Connector Set...
Home Logo
32 people viewed this question
Top Duravit Home Experts
Craig Butler
Craig Butler
US Parts Center
US Parts Center
Andrew Taylor
Andrew Taylor
Are you a Duravit Home Expert? Answer questions, earn points and help others
