SOURCE: Cannot figure how to open top cover
The top of the machine does not open. You have to remove the console to get to the retaining clips that hold the entire case on the frame. If you wish to pursue this follow these steps: 1. Unplug machine. It's best not to have any live voltages when working around the console. 2. Lift console. It will come off in one of two ways depending on what type you have. The end caps on either side of the console are removable on some models by popping them off to the expose a screw on either end. If teh end caps don't come off, you will have a retaining clip holding it in place on each side. With this type, you will need to insert a putty knife (from the FRONT of the console) under each corner and push in to release the retaining clip. 3. Once the console has been lifted from the top, carefully lift up and back to its resting position over the back panel of the machine. Use care when when doing so that you don't break the plastic hinges that hold the console in place. 4. There are two brass-colored clips under the console that you need to remove. Insert a flat screwdriver straight down through the top into a groove in the clip and pry towards the back of the machine. This will release the clip. 5. Once the clips have been removed the entire case comes off as one piece. Make sure you disconnect the lid switch connection on the top of the machine first. This will be a plastic white connector plug. Open lid and place one under the front rim of the case and pull from the back towards you. The case will lift off from the back first and off the frame. 6. Replacing the case is always the tricky part. Looking down through the lid of the case, make sure you place the bottom front lip UNDER the frame first and slowly lower the case on to the frame. There are four cleats the must fit back into slots on the frame before it will seat properly. Also, make sure the back fits back into the casing on both sides or the retaining clips will not go back in properly. Insert the clips into the slot on the back panel first then push down on the opening on top of the washer for them to snap back into place. Now, I don't know if you still want to try to tackle this or not. It does seem like a lot, but it really isn't once you get the procedures down. If it's just a simple matter of cleaning because the washer smells, the odor may be coming from the wash tub itself. Running the machine on empty, with the hottest water cycle you can with a cup of bleach can go a long way towards killing bacteria and mildew. Just another thought to save you a lot of effort. Good luck. I hope this helps you.
SOURCE: My eggs bottom peice was sweating black tar
Funney no one has answered this at all and this is an old question. But the answer is rather simple. There is nothing wrong with your egg. Yes it is possible under the correct tempurature for this sweating to happen. BGE is made of ceramic material. and one must understand that ceramic material is porous. Yes the BGE is porous from the inside all the way to the outside. Very tiny micro channels of ceramic hold water and when heated gets released into the grill as well as well as release on the outside of the grill. Of course this does not always happen. Normally the grill must be running for a ceratain amount of time and or reach a certain tempurature for this to occur.
