SOURCE: No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
SOURCE: jet ski will not run at full throttle
Jet skis have a problem with the fuel pickup tube in the tank getting plugged up,also check to see if your exhaust is getting to hot,you should be able to keep your hand on it without getting burned if your water jackets are not plugged
SOURCE: Torque 1998 Tiger Shark 770 jet ski, blew out head cover gasket.
Inside-out in a cross pattern. Cases/cylinders 25 ft./lbs., Head 22 ft./lbs.i
SOURCE: how to replace seal on a jet ski
The seals in the drive pump can be replaced by taking off the ride plate and pump housing. To replace any other seals (engine or hull) you will have to remove the motor from the hull.
