SOURCE: need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
SOURCE: Engine speed varies
If the unit was stored for a long period of time (6-12 mo.) with gas in it, you may have a gummed up carburator. This is the most common problem with generators (lack of use)
The carb. would have to be removed & cleaned, specificly, the high & low speed jets
SOURCE: I have a Honda F501 tiller. It quiy on me so I
Sounds like somthing may have been disturbed when removing the flywheel if the engine revved fine prior to dying on you.
Theres a guy on ebay selling workshop manuals for Honda, see if he has an F501 manual? Heres a link to one of them I got recently
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110441313372&ssPageName=ADME:L:EOISSA:GB:1123
SOURCE: Governor and Carb spring linkage
the solid wire link goes from the top hole in the governor rod to the carb and the spring goes from the lower hole on the rod to the throttle plate where the cable attaches
SOURCE: Lawnboy Model 10424 how much tension to put on the Air vane
mower will not idle up under load. does not stall but idle slows any help would be appreciated
John
