This sounds like a similar fault I repaired on a Fisher Paykell top loader smart drive. It would fill up, start it's wash cycle (you'd hear the engine turn back and forth ) and a second later stop. It turned out that a position sensor on the motor had failed due to a small water leak. I'm unable to find the motor for your model of Frigidaire to see if there is a similar sensor or pick up module though.
Hello msmm50 - Contact a professional so they can properly and accurately diagnose the unit for repairs. Sounds like you have a leak in the drain lines or the water valve.
Yes, Remove two screws rrom bottom of washer using puddy kinfe release the top panel bysliding in at crack between top panel and body the water pump is at the bottom left and may be leaking from hoses the other posiabilty is the selonid that controls the water inlet may be leaking
