The Engine is used for gas compressor
SOURCE: Both forward and reverse speed are decreasing
Hi, check the main drive belt, the belt is stretched out. you need too replace the main drive belt.
If this doesn’t work for you, please write back. Thanks,
SOURCE: engine almost stalling when ac is turned on
you may have a faulyt IAC sensor not idling up enging when a/c is on
SOURCE: low idle speed cause engine stop?
depending on what kind of car it is i would change the idle air control valve and clean throttle body if applicable
SOURCE: cold engine, idle rpm 1200 is this normal? 2002 Toyota Carollia
you need to replace the throttle position sensor on the intake.
SOURCE: Jeep grand cherokee 1995 4.0 engine laredo.
I'd check the throttle position sensor, map sensor and all linkage and cables that control the transmission. Could be a problem with one of those items or, you may have a problem either with the converter in the trans, the solenoid that operates trans converter lockup or possibly even the switch on the brake pedal. Do not just change anything I mentioned because I mentioned them, test each item for proper operation and if "stuck" with trans testing, have a good trans shop do a diagnostics on it for you.
Engine stalling and rough run
issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
