I have an older Samsung smart tv. It has Netflix and amazon preloaded. How do I get Acorn loaded on tv. The tv is not wireless but is hooked to internet via a cable.
SOURCE: Is it possible to update Samsung 1500 so that it
At this point in time, the 1500 cannot stream from Netflix.
SOURCE: the Netflix app on my
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
SOURCE: Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I just got this Vizio
Before you go to any more trouble troubleshooting potential hardware and/or connection issues, look at this page of reviews on Dell's site, taking special care to read 'Review 8' by an owner named 'Milwsport'.
Testimonial: "thanks for the quick informative response!"
SOURCE: I have both my iMac & Samsung Smart TV
There's an adapter that monoprice.com just brought out that I purchased.
Works like a charm. It still plugs into the mini display port but it
also has a usb connector that you must plug into one of your usb ports
on your imac. This allows for the audio to travel over the hdmi with the
video. The link is below.
http://www.monoprice.com/products/product.asp?cid=104&cp_id=10428&cs_id=1042802&pid=5969&seq=1&format=2
Be aware that once you add the TV as a second screen that it extends
your desktop typically to the right of your current one. Just drag an
open window to the right and it appears on your TV. The resolution of
the TV is probably lower than the mac screen so the extension is a
different size. You can move the extension around to the
top/bottom/left/right etc.
You can see this in Preferences - displays - arrangement, After you have added your second screen.
If you don't want to extend the desktop but would rather mirror your primary display, this is where you check "mirror displays"
