SOURCE: Honeywll Chronotherm 3 reading Hold AC
the power to your furnace has been turn off. check the switch at the top of the stairs.
SOURCE: Sears Model 3 41A4315-7D Have 2 remote controls
You might try programming them this way if you haven't already.
Press and hold the button down on your remote and then press and immediately release the smart/learn button. Do this for both remotes.
Press and immediately release the smart/learn button and then walk over and key in your 4 digit code and press enter on your keypad.
What was the problem that made you decide to "reset the codes"? May be a clue to your problem.
SOURCE: Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
SOURCE: keypad won't program to garage
It sounds like the keypad is not compatible with the main garage door. Make sure the keypad is the correct only for that model number opener. Older models will not work with newer openers and vice versa.
SOURCE: I changed battery in remote
Remote Key FOB Information
Transmitter Programming
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to 4 transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
9. Operate the transmitter functions in order to verify correct system operation.
If this does not work, you may need to have the dealer do it with a scan tool. Make sure you take all the remotes you want to use with the car if you have to go this route.
