Question about Golf
2006 electric golf cart back brake won’t work need the wire new lights but still won’t work any clues
SOURCE:
weblord
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
gaggid
  • 80 Answers
SOURCE: need wiring diagram for ez go golf cart modle x444-3p
This might be useful for you. Check it out.
http://server1.buggiesunlimited.com/phpBB2/viewtopic.php?t=6298
Posted on Dec 28, 2008
SOURCE: 1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
Posted on Jan 22, 2009
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
HOW TO GET THE PART NUMBER FOR THE REAR BRAKE SHOES FOR MY RUFF AND TUFF GOLF CART
E-Z-GO Golf Cart Brake Shoes - Genuine E-Z-GO Parts and Accessories
https://shop.ezgo.com > Shop > Parts > Brake Parts > Brake ShoesOEM Golf Cart Brake Shoe 4084 ' Single Shoe. Fits 1996-current E-Z-GO Golf Car and Utility Gas & Electric Vehicles. Item #: 648037. $24.70/ea. Spring- Shoe Return- LH (Blue). Used on 1996-Current E-Z-GO Gas & Electric 4/6 Passenger Shuttle, ST Express, 875, 881, 950, and Cushman Titan Vehicles; in addition to ...
Nov 30, 2017 | Cars & Trucks
1986 ez electric 4 seater golf cart serial # 438359
re wire the golf cart. poor ground and possible battery replacement needed
Sep 15, 2016 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
We are searching for a schematic for a Legend electric golf cart
THE BATTERIES ARE RUN IN SERIES THAT MEANS THAT THE WIRES GO POS. TO NEG. NEG. TO POS. STARTING IN THE BACK AND THEY RUN LIKE THIS TILL YOU GET TO THE OUTPUT FROM BATTERIES TO MOTORS THE CURRENT GOES IN ONE SIDE OF BATTERY AND OUT THE OTHER BY CONECTING ALL POSITIVES YOU MAY HAVE JUST KILLED THE BATTERIES
Jun 15, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Free wireing diagram on a 1987 DS Electric golf cart
I have 1987 club car golf cart. I need the battery wire diagram.
Jan 01, 2009 | Electronics - Others
Golf Logo
56 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
