Acts like posi is locked up
SOURCE: Hit a curb 1999 Ford Taurus SE 16" wheels steering problem
An aligmnment check will only get u an answer on what the problem is, if anything is bent/damaged, they can not align the front end with damaged parts, don't drive this car until u find out what is wrong.
SOURCE: locked steering wheel
try to spray inside the key lock cylinder (the place where u put ur key ) by PB puster or WD40 then turn the steering wheel lift and right with try to turn the key to position on
i hope this will help
SOURCE: cannot unlock the steering wheel on oldsmobile intrigue 2001
is it the right key for that car? cause if not then that is the problem... if it is the right key, then you might have to replace the key cylinder cause you may have something broken in it...
SOURCE: ignition key won t turn. steering wheel locked
the key may be worn badly or the ignition needs to be replaced.
SOURCE: steering problem
If it is 4wd you may have a problem with your front differential. GMCs are known for having front differential axle seals leaking. If all the fluid is out metal parts may be binding.
