Question about Garden
Lawnmower model 944607352 15.5 hp when running level ok lean to left or right smokes , white smoke?
SOURCE:
  • 48 Answers
SOURCE: white smoke
the white smoke is oil - did you overfill the oil ? if you tipped the machine your air filter could be full also - if this is an old machine it could be ready to throw a rod but not enough info from you to tell
Posted on Oct 27, 2008
SOURCE: TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
Posted on Mar 21, 2009
  • 10865 Answers
SOURCE: White Smoke comming out of Briggs and Stratton 21 HP V2 engine.
The white smoke may have been caused by having water in the fuel, or fuel tank [due to condensation or exposure to rain and snow]. It may have been that the mower got tipped for cleaning purposes, blade inspection, etc. and oil from the low lying oil pan got into the piston.
Either way, I recommend installing a brand new spark plug and new gasoline [you can purchase a little gas siphoning hose for a dollar or so at any auto parts store] If you have gasoline left over in a can from last year it is safe to use it in your car as it mixes with lots of new gas, but not in your small mower tank as it is basically outdated fuel.
Posted on May 19, 2009
  • 7 Answers
SOURCE: lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
Posted on Jun 09, 2009
  • 68 Answers
SOURCE: Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Posted on Sep 06, 2009
1999 Harley Davidson FLHR Road King white smoke from the left exhaust
Hi, Kevin your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on startup is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on startup may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below and for more specific information or questions at no charge feel free to contact me at xlch@mail.com. Good luck and have a nice day.
White smoke from exhaust Harley Davidson Forums Harley Davidson Motorcycle...
1999 Harley Touring Service Manual pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm free owners manual
Instant Tech Relief To speak to me personally for only a mere $6
Apr 29, 2018 | Harley Davidson FLHR Road king Motorcycles
When my bike is running I get white smoke from the right side exhaust and the right side also blows harder than the left. What could this be?
IF you are running stock pipes (not "True Duals"), the right pipe exhaust ALL from the front cylinder, and SOME of the rear, and the left pipe only blows SOME of the rear alone.
The stock rear pipe splits, some going to the left pipe by itself, and the rest going to the right pipe WITH the exhaust from the front cylinder.
Now, white smoke usually indicates moisture.
Being a (non-VRod) Harley, that eliminates the liquid coolant, because there is none.
Next up that comes to mind is condensation.
BUT, this would burn off fairly quickly.
So is the white smoke only at first, or even when warmed up?
And if warmed up, is it actually coming OUT of the pipes, or OFF the pipes (like some oil burning)?
May 19, 2014 | 2000 Harley Davidson FLHT Electra Glide...
White smoke comes out when I pull the cord.
Did you notice this after the engine oil was changed. If you overfill oil it will smoke. Check oil level. Let me know if this helped. I have other ideas, but this is the most common problem with smoking.
Jul 06, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I stored my lawnmower on an angle all winter. Yesterday when I tried to start it oil came out of the exhaust. Today it started with alot of blue smoke, of course. what's my next step?
Just make sure the oil level in the crank case is OK, then just run it. The smoke will burn off once the muffler heats up, but it may take a while. The smoke is annoying, and not all so environmentally friendly, but it won't do the mower any harm. Just because the oil leaked into where it wasn't supposed to be, it doesn't mean that you have increased the ability for oil to leak that way. Good luck, Al K
May 19, 2011 | Briggs & Stratton Briggs Stratton...
Smoke from engine of lawnmower
usually large clouds of smoke are from having too much oil in the crankcase, or tipping the mower so that oil runs into the cylinder. Check the level of oil, and make sure it's not overfilled.
Mar 26, 2010 | Pool & Spa
Lawnmower is spewing white smoke
Jun 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
