Question about Mitsubishi WS-55511 55" Rear Projection Television
My model is a WS-55511. I turn on the TV, the
My model is a WS-55511 and was purchased 1/03 . I turn on the TV, the green indicator light comes on for about five seconds and then goes off. The screen never gets a picture during that five second period.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Posted on Aug 08, 2009
    New Friend:
What do i have to do to get my color set on my tv to watch a movie\
Posted on Apr 24, 2013
SOURCE:
When you turn the tv on it go right back off Mitsubishi WS-55511 55 in. It about (5)yrs old I have try unplugging the tv for about 3 to 5 minute
Do this: When you turn it on and the green power light comes on and goes off:
On the front of the set press and hold BOTH the Menu and Input buttons at the same time for at least 5 seconds and then release both.
This model has a self check: The green power light will then blink a two digit error code: most common is 2 blinks, 2 blinks and a pause and repeat the error code at least 5 times.
Let me know what you find and I will tell you what it means.
I hope you get 2,2 as it is the most easy to resolve.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The green light on the front panel is flashing but
Try website Tvrepairworld.com to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The power outage went out yesterday and my tv wont turn on
Most likely it is capacitors on the dm board that have gone bad. This is a fairly common problem and has been addressed on fixya many times. If you know someone who is good with soldering and technically incline or even an honest electronics guy then the repair is quite cheap. If you have any other questions please let me know. if its not the capacitors on the DM supply then its a problem with the whole DM assembly that part usually is around 300$. So you may want to consider purchasing a new tv. Trying the 7 caps on the dm supply board shouldn't cost much if it takes anything more then that. I would sell the tv on craigslist or ebay and recoup as much as you can towards your next tv.
thank you,
lee
Thank you,
lee
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My mitsubishi hdtv1080 is stuck on camcorde, how can I get it off?
When I turn the Mit. 1080 on, the green indicator light comes on for about 3-5 seconds then it goes off. TV never comes on (no picture or soun, nothing). What is the problem. thanks
Feb 06, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green light blinks and cant turn tv on
If this is a WS-55511, it is probably caused by a DM module. Unfortunately, it is not available nor does Mitsubishi offer a rebuild option. Mitsubishi's phone# 1-800-332-2119.
Give them a call and you never know what they may offer you.
Hope this helps,
Skyassoc
Jun 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
584 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
