SOURCE: Microphone suddenly stopped working
Try uninstalling and reinstalling your sound card driver. Also do the same for any software that has anything to do with your sound card. If this diesn't work, try restoring to a point before you had the problem. If you is usb and one is standard then it has to be soundcard or software, more then likely it's a driver issue.
SOURCE: I no longer hear the clicking sound when I click
Relax, nothing wrong....
click is simply a user's preference.
Old old keyboards used to click all by themselves. Now the keyboard uses the onboard speaker to do its clicking.
Go to "Sounds" in the [Control Panel] and un-mute the speaker.
I prefer no sound...
SOURCE: i cannot hear sounds from my computer.
i have a compaq presorrio cv735 and have no sound. how can i fix this?
SOURCE: Had the compact refrigerator for about 4 years
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
