Turns on however, it will not open the cd tray from front panel or remote.
The belt is very loose on my Rotel CD player although it does not look perished. I used an earbud to clean the belt with water. Take of the cover. Power off. Move the tray in out with your hand and hold the earbud underneath the belt. Once clean mix sugar and water and apply to the belt. Wait a bit for it to dry. It works like a charm. My 26 year old Rotel still going strong :-)
Hello Ruben, so you do not open the CD holder tray of your Rotel, the problem is that the belt that transmits the rotation of the engine to the mechanism of the car, may be stretched and therefore the car does not open, this is the most common fault in this type of CD players
You should replace it, if you can not do it, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Ruben, por lo que cuentas, no se abre la bandeja porta CD de tu Rotel, el problema es que la correa que trasmite el giro del motor al mecanismo del carro, puede estar estirada y por lo tanto el carro no se abre, esta es la falla mas habitual en este tipo de reproductores de CD
Deber?s reemplazarla, si no puedes hacerlo, busca un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://elektrotanya.com/rotel_rcd-951-tm.pdf/download.html
http://bwgroupsupport.com/downloads/manuals/rotel/RCD-951-OM.pdf
Testimonial: "Franco, thanks for your help. By any chance where can I purchase the belt? According to specifications is the rotel 3-653-387-(1)."
SOURCE: Sony CDX M8800 Front Panel Problem
ribbon cable needs replacing ive done it many times i have the instructions in colour very easy for £4.99 posted to you
SOURCE: Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
SOURCE: hi there . i have
Hold the function button in while it says CD.
Turn the machine off then on.
Try to eject now.
Worked for me.
This was achieved accidentally so if it doesn't work first time, try various combinations using these two buttons.
SOURCE: CD tray not opening on Denon RCD-M35DAB
there are tthere are two transparent plastic switches under the tray
there (a gray plastic piece, intcasing the loading motor is nonot rotated enough, not allowing the necessry pressure on the switch.
you must in either case disassemble the reading module comprising the tray, otics annd spindle, so you gain access to the underside of it, from ence coperatrepositioning the tray or the lrotating the trigger\eloading motor.
SOURCE: cd ejection tray
From Standby press function, whilst holding function press power (both on the main unit).
The display will show demo mode, this has now disabled the mode.
Regards Graham
Testimonial: "sir, many thanks for this , great to recieve info for the unit , its now working fine, good to be able to listen the sounds again ! "
