If the Cannon Micro Printer 50 is not showing the entire display, there are a few things that could be causing the issue:
- Screen settings: Check the screen settings to make sure they are set correctly. Adjusting the brightness, contrast, and screen size settings may help fix the problem.
- Low battery: The issue could be due to a low battery. Make sure the printer has a fully charged battery and try turning it on again.
- Loose or damaged cable: Check the cable connecting the printer to the computer or power source. If the cable is loose or damaged, it could be causing the issue.
- Software issues: There could be a software issue causing the problem. Try updating the printer's software or reinstalling the driver.
- Hardware issues: There may be a problem with the printer's hardware. If the above steps do not resolve the issue, you may need to contact Canon customer support or take the printer to a technician for further troubleshooting.
In any case, it is best to refer to the user manual or contact Canon customer support for specific instructions on how to troubleshoot and fix the issue.
