Hello Jim, for what you comment, your Blu Ray, would have reader problems, dish motor or controller
I suggest you look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Jim, por lo que comentas, tu Blu Ray, tendr?a problemas de lector, motor de plato o controlador
Te sugiero busques un servicio t?cnico especializado
Espero Puedas resolver el problema
Saludos Franco Dosil
Testimonial: "Hi Franco, the BP125 is 2 years old and a cheap one. I'm not going to fork out any cash on 'expensive' repairs - in the bin it goes!!! Thanks for your help - I didn't think there was any 'easy' fix."
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
SOURCE: LG super blu player won't play blu ray disc
Have you updated the firmware on it? I had a similar problem with a Sony blu-ray player and I had to download an update and burn it on to a CD then allow the CD to update the blu-ray player. What's the model number of your player, I may be able to get a link to the update for you.
SOURCE: LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
SOURCE: have a lg blue ray player that makes loud noise and says disc error
This is a hardware issue.
The LG drives motor attaches to the top rotor by help of a magnet, which fixes the disc so it can spin symmetrically. For this to happen, the drive unit has to have a fixed piece of metal. Now, this particular metal ring gets loose quite easily and then permanently sticks on the top of the unit, where the magnet is situated. As it is now loosely attached to the top of the drive unit, the optical disc will spin errandly, that is where the clunking, rattling noise comes from.
To fix it, you must open the LG player and the drive unit, which is really simple to do, and glue the metal ring back in its original position.
Thats how I did it and the drive now purrs along quietly.
PS
LG really produces those units cheaply, that is the reason the metal ring detaches so easily.
