SOURCE: I need an instruction manual for the Tork 1101
go here:
http://www.weisd.com/store2/TOR1101.php
click on the wiring diagram
SOURCE: Tork Time Switch runs in reverse direction
On my Tork 1101, the off switch was sticking and stopped the motor which then ran in reverse. Turning the power to it off and on will get it running the right way. Cleaning and lubricating the off switch might stop the sticking.
SOURCE: I have a Tork timer model number 1101 24 hr time
Tork 1101 is a 120V mechanical dial-type timer
Tork 1100 series
To set timer, you lift and rotate dial. Line up current time with the word Time located to lower right of dial.
Next, place trippers on dial. Dark trippers are OFF and light-colored trippers are ON
Tork 1101 is 120V timer.
120V Black Hot wire from circuit breaker connects to Pole L
There is a brass bridge that connects Pole L and Pole 1 >> if this is missing, put a jumper wire that connects both Poles
120V White Neural wire from circuit breaker connects to Pole X
White wire going to Load (lights, fan, motor) connects to Pole X
Black wire going to Load connects to Pole 2
Up-vote if this information was helpful. Thanks for the feedback.
SOURCE: I have a tork 1101
This is for 120 volts ONLY. The incoming "main" black wire from the circuit breaker or source connects to terminal 1. Leave the bridge in place between L and 1. The outgoing black wire to the load connects to terminal 2. Both white wires connect to x.
SOURCE: I have a 15 yr old tork 1101 pool timer. I
1) Tork P47 tripper is correct tripper for 1101 timer.
Trippers are brass-colored and black-colored.
If they do not fit timer dial you might need new timer.
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
2) Buy new 120Volt indoor/non-weathertight Tork T1011
To identify timer for sure:
http://waterheatertimer.org/Tork-timers-and-manuals.html
3) Google search Tork 1101 shows timer cost $83
4) Intermatic cross reference shows replacement is T-101 indoor/non-weathertight
Amaxon sells T101 for 43$:
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
5) Raintight/outdoor: Aplus and Lowes sell raintight outdoor T-101R for $71
http://www.lowes.com/pd_29405-251-T101RD89_0_
http://www.aplussupply.com/intermatic/timer.htm
6) Cross over wiring.
Tork terminal X is T101 terminal A
Tork terminal 1&L are T101 terminal 1
Tork terminal 2 is T101 terminal 2
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
