https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe... Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small. But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out. Let me know how it goes.
I would bet that the throttle shaft is worn and has a lot of play in it on the carburator. This is very common. The best bet is to have the carburator worked on by a small engine repair shop, or get a replacement one.
This condition is typically caused by a dirty air filter, water or trash in the fuel system, a break or leak in the plug wire, or a misadjusted or malfunctioning governor. Hope this helped and best wishes.
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
