This unit doesn't have the proper spindle, just a low ridged hump. It ties the clothing into knots. Very difficult to balance the loads for a proper spin cycle. I think if I could put in more water, it might solve the problem...
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below)
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
SOURCE: maytag atlantis washer
Start by checking the belt by tilting the machine back and examining for wear, glazing and cracks, next pull the belt to make sure everything turns. Post back if this looks fine.
SOURCE: Clothes are soaking wet after the entire wash cycle.
The motor controller is likely bad - not getting to the HIGH spin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Hi
If clean light is blinking then it may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry. Now let the unit run for 2-3 minutes and then you press
the Cancel/Drain button and allow it to completely drain and reset. If this
doesn't work then it's an issue with the wash pump not pumping the water past
the heater efficiently or due to lack of water to heat. Please make sure that
heater is not open circuited and is heating the water efficiently. You'll have
to check the heater using a multimeter; the meter should read between 3000 to
3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure
water pressure is optimum and fill valve is working fine. Hope this helps...
Please post back if you need more information.
Daniel
Hi
Daniel
Hi
Daniel
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Hi
Daniel
Hi
If clean light is blinking 7 times then it may be an issue
with heater circuit, door switch or wash pump. If yes then please reset the
reset.
fine.
information.
Daniel
