SOURCE: my recorder says "full" when i try to record, but i have deleted everything!!??!!
Solution for this problem is to Format the recorder. Step 1 is to turn on unit. Step 2 Press Erase " Delete will flash on the display. Step 3 Press and hold Rec for 3 seconds "Format" will flash on the display. Step 4 Press and hold Erase, the completed percentage will show on the display (formatting is now in progress). Step 5 After formatting is completed the remaining time will show on the display. You should now be able to record. Make sure that you hold the ERASE button in step 4 until Formatting shows 100% complete.
SOURCE: DMR-ES15 Stops after 45 Min.
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
SOURCE: dvd/vcr recorder stops recording
DVD-RAM itself, and DVD-R formatted in "VR" mode are SUPPOSED to allow for recording "ONE TIME" per DRMA. The broadcasters are probably sending the wrong copy protection signal if the -RAM & -R/VRmode are stopping.
At least, that is my understanding.
tom
SOURCE: Lenovo Y410 gets switch off while usage !!!
Sounds to me that you have an overheating problem. Can you hear the fan come on? Can you feel the hot air being pusheed away from the computer? Have you got it sitting on something soft like a bed or pillow or something which is stopping the intake of fresh air?
SOURCE: My thomson DTI6300 digital TV recorder shows that
If you have no recordings and it's playing up, I'd do a complete reset as follows;
Restore Factory Defaults
This will restore all the factory settings and erase the contents of the box.
Menu>Set-up>Help>Green>Red
Format HDD
This will re-partition and re-format the hard drive.
Menu>Set-up>Help>Green>Blue
This will wipe everything you have recorded. It will also dump your 14 day Electronic Program Guide which will take upto a day to reload. Leave the unit on standby.
You might want to take this opporunity to do a channel scan as well.
