SOURCE: Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
SOURCE: I have an antique waterbury wall clock, how do I
INFO:
As long as it is not in the date advance cycle some where around midnight you should simply be able to reach around to the back of the disk and rotate the dial.
DISCLAMER:
Tip provided sight unseen.
Clock not fully described.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
SOURCE: tempus fugit westminster mantle battery operated
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
SOURCE: i have my mother's seth thomas mantle clock
If your clock has a small hole between 4 and 5 then you can turn off the quarter hours chimes using the small part of the key. If your clock does not have that small hole you can not turn off the quarte hor chimes.
