Meo Mantralayam Posted on Jun 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to resove service code sc556 in sp210su in recoh printer
dagem aberham
Level 2:
Guru:
  • Expert 123 Answers
  • Posted on Jun 03, 2019
dagem aberham
Expert
Level 2:
Guru:
Answers
123
Questions
Helped
52726
Points
604
Ressure roller fusing lamp temperature fluctuation The pressure roller temperature changes by ±20°C or more in one second. This occurs three times in one minute or two consecutive times.
Causes
• Loose connection of the pressure roller thermistor • Loose connection between the fusing unit and main frame
Remedy
1. Check if the fusing unit is properly set and connected to the main frame. 2. Check if the pressure roller thermistor connector is firmly connected. 3. Replace the fusing unit.
Ricoh Aficio AP3850C Error Codes
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/34525-ricoh-aficio-cl7000-sc-556-error-code.html
2 Related Answers
Anonymous
  • 62 Answers
  • Posted on Nov 16, 2007
SOURCE: Recoh AP3800C ERROR 543
This is an overheat problem and will most likely come back. you can press CLEAR-1-0-7-STOP buttons in sequence holding down the stop button when you get to it. You should see a service screen come up if you do this correctly. Go into the first button (i think it says copy). you should now see a list of buttons1 through 9 usually. look in the 5 & 7 buttons. You are looking for something that says FUSING RESET or it may say SC RESET.push that button and reboot the machine. If that doesn't work check ebay for a new fuser.. It will run you $125-$150 there verses $250 from a dealer.
Anonymous
  • 132 Answers
  • Posted on Dec 01, 2008
SOURCE: Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
times.
the pressure roller
thermistor 1. Check if the fusing unit is properly set
• Loose connection 2. Check if the pressure roller thermistor
between the fusing
unit and main frame
2answers
Printer Ricoh sp 210 su in error service call sc556
This is most likely a fuser issue. If you have a spare laying around, I would suggest replacing your fuser. If you have a contract with Ricoh, I would suggest placing a service call for them to come out and look at the machine.
2answers
How to solve service call sc556
Do what it says and call service.
Sc556
To reset fuser SC codes you need to enter Service Programme Mode and reset SP5-810 to 1, then turn the main switch off and on again. If you need help on entering SP mode etc. then take a look here.
I want total codes and details of code,s about recoh ft5832
Check on copytechnet.com. There are authorized Ricoh technicians who might be able to help you with this matter.
Top In Office Equipment & Supplies Experts
Paul Carew
vince
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
