Everything on my laptop works except my screen. it just stopped working for no reason. is there a sequence of bootons i need to push to fix it or is my screen just out?
It could be the 'back light' is burned out.
Or
Press Fn and F5 simultaneously to make sure the display
priority is not set for the built-in screen.
Or
Press the 'brightness up' key a few times.
Display problems
Here are some typical display problems and their solutions:
The screen is blank.
Display Auto Off may have gone into effect. Press any key to
activate the screen.
You may have activated the instant password feature by pressing
Fn and F1 simultaneously. If you have registered a password, press
any key, type the password and press Enter. If no password is
registered, press any key. The screen reactivates and allows you to
continue working.
If you are using the built-in screen, make sure the display priority is
not set for an external monitor. To do this, press Fn and F5
simultaneously (once). If this does not correct the problem, press Fn
and F5 simultaneously again to return the display priority to its
previous setting.
HINT: Holding the Fn key and pressing the F5 key several times will
advance you through the display options.
If you are using an external monitor:
❖ Check that the monitor is turned on.
❖ Check that the monitor’s power cord/cable is firmly plugged in.
-- Try adjusting the contrast and brightness controls on the
external monitor
SOURCE: screen not working
you could try the function key (FN) and one of the F keys. not sure, may be F5 or F8 to change the display to laptop screen and external monitor.
if this does not work you could have a broken LCD lamp.... Most likly the 1st solution
