Looks like a rheostat of sorts... possibly for audio volume control.
I've been a code inspector (and plans reviewer) for over 40 years and have never seen anything like this. As it has an "off" setting, someone may have grabbed whatever he had and used it as a switch.
Things like this scare me. Whatever its connected to, I would find out (by following the wires) and disconnect it. It's things like this that cause home fires.
SOURCE: Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
SOURCE: generator electrical
On a 230 volt std hook up here's the way it is supposed to work. From black to white you should get 115 volts. From Red to white you shoudl get 115 volts. From red to black you should get 230 volts.
Concentrate on getting the correct output from the generator with the load to the house disconnected
This should be 115v (black to white, 115 volts red to white and 230 volts red to black.
On the load side (ie, the house connected) what are you using? 115 volt lights, etc on one side of the
230 volts, and some other 115 volt loads on the other side.. Are there any 230 volt loads. It could be
that one side of the 230 volts (ie, a 115 volt side is drawing a lot more current than the 2nd 115 volt leg.
Get back with me on just what the loads are botth 115 volt and 230 volt . also what are the rating on the circuit breakers.
Loringh
SOURCE: Help - I am trying to install a honeywell RLV4300A
You will have to have schematics from the old wiring diagram. Then you will have to confirm its consistency with actual old wiring before you can be sure that the wires run to the proper places on the old heater and a/c system. This sounds like a gas furnace and is simpler than a heatpump. Once you know what distinguishes the wires with the same color, you should label them and then you may call them a different color if they were wired with wrong wire colors. You may be in luck if you go to the furnace control box an look at the terminals.. They are usually labeled with a R for Red and W for white and Bl for Blue and B or Black. If you have other colors on these then it sounds that it was wired with wire spare wire by someone who knew what they were doing but neglected to leave a path for someone else follow.
You may be able to use a continuity tester of circuit tester to id these wires that are in question...
ie, once indintified, you can match with the requirements of the new stat.
SOURCE: Which cables do I need to connect my turntables to the mixer?
Your submission wasn't complete. Please resubmit.
SOURCE: Have a Leviton dimmer with red, black and green
You are correct in assuming green is the ground and connects to bare copper wire. Black is always the HOT wire and should be attached to the black wire. Red wire connects to white wire.
