Optics Logo
h
herb fischer Posted on Jun 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bushnell is stuck on meters how do I get it to yards I have the tour v3 it was on yards and now is only on meters can this be fixed,im on a golf vacation in 12 days
john h
Level 3:
Top Expert:
  • Bushnell Master 29,494 Answers
  • Posted on Jun 03, 2019
john h
Bushnell Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7558972
Points
193449
This is your owners manual https://www.manualslib.com/manual/1452768/Bushnell-Tour-V3.html
4 Related Answers
Mr Tech Geek
  • 133 Answers
  • Posted on Apr 11, 2009
SOURCE: Meters to Yards
If the unit has a "mode" button, hold it down for at least 5 seconds and see if the "Y" comes up on the screen. Let me know if that helped...mtg
Micoman
Jorge Luis
  • 198 Answers
  • Posted on Sep 22, 2011
SOURCE: Bushnell voyager sky tour 700 mm x 3" missing
You can buy Eyepieces and Barlow Lenses
I recommend buy on
http://www.bhphotovideo.com/c/product/765322-REG/Bushnell_789931_Voyager_Sky_Tour_700mm.html
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
adamhoward_1
Adam Howard
  • 63 Answers
  • Posted on Jun 04, 2018
SOURCE: What is the Bushnell Tour V4 Golf Laser Rangefinder product specification?
I have a Bushnell Tour v4 Golf laser Rangefinder.
Bushnell Tour V4 Golf Laser Rangefinder brings to you the next evolution of pin seeker with jolt technology. It provides an unbelievable pack of features set into a smaller and ergonomically sound form factor.
Here is the specification:
  • Product Dimension: 2.6 X 2 X 1.3 Inches
  • Pin Seeker
  • Color: White
  • Weight: 12 Ounces
  • Warranty: 2-Year Limited Warranty
terryskelly
Terry
  • 11377 Answers
  • Posted on Aug 01, 2018
SOURCE: My Bushnell Tour v3 is stuck on 1888YM+18 888 can you help me please Thanks D Fitz
Contact Bushnell for help.
https://bushnellgolf.com/support/
Support
https://bushnellgolf.com/contact/
Contact
Bushnell Tour v3 laser rangefinder will not display yardage
Please shutdown your device for 5 minutes, booot up and then check for yardage again. If this does not work, then you might look into the device manual (in troubleshooting) to check for an alternative approach to fixing this. Thank you.
Change meters to yards Bushnell Tour v3 slope
UNIT OF MEASURE OPTIONS The YARDAGE PRO TOUR can be used to measure distances in yards or meters. The unit of measure indicators are located in the upper right portion of the LCD. To select between yards and meters, look through the monocular, depress the "mode" button (left side of the unit underneath the BUSHNELL YARDAGE PRO logo) and hold it down for approximately 2 seconds. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the letter M for METER indicator while the YD for YARD indicator is turned off. If you are changing from meters to yards, the opposite will occur. Note: The YARDAGE PRO TOUR will return to the last setting used, each time the unit is turned on.
Need to go back to yards from meters
To select between yards and meters, press and hold the POWER/FIRE button
V3 change meters to yards
MODE and UNIT OF MEASURE OPTIONS
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower
right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will
begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature,
see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to
select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the
M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite
will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
V3 not jolting
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature, see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Feb 12, 2014 • Optics
2answers
My rangefinder is giving the wrong yardage
Anyone of you have an idea about the best golf range finders?
2answers
Can my bushnell yardage pro rangefinder be calibrated. It is 4 yards off at 30 yards and 7 yards off at 40 yards. So on and so forth
I would send this unit in for repair to have it inspected you can reach their customer service at 800-423-3537 option 1.
14helpful
How do I change Meters to Yards
Hold down the button on the side for at least 5 seconds. The "Y" will appear in the display....Now its set back to yards.
mtg
Top Bushnell Optics Experts
ZJ Limited
ZJ Limited
john h
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
