A
Anonymous Posted on Jun 02, 2019
I need owner manual for sony ICD-B500 recorder
How do I delete recordings?
Terry
Level 3:
  • Sony Master 11,377 Answers
  • Posted on Jun 02, 2019
Terry
Sony Master
Level 3:
Answers
11377
Questions
Helped
4619873
Points
152765
5 Related Answers
Anonymous
  • Posted on Jul 10, 2008
SOURCE: ICD-B500 Recorder
An adapter will not fix the problem. The files cannot be transferred to a computer using a USB port. The files must be transferred analog using the recorder's headphone cord. The files are then recorded to the computer from the Sony recorder using a program such as Windows Recorder. The ICD-B500 has many great features but archiving to a computer is not one of them.
javer821
Javier Gonzalez
  • 207 Answers
  • Posted on Apr 04, 2009
SOURCE: Deleting recordings off sony icd-mx20
Display the folder o message in the folder that you want to erase.
Press Menu and select Erase by using up arrow down arrow and then press play stop button, the cursor moves to erase menu.
Press up arrow down arrows to select erases all the messages or message in a folder.
Press up or down arrow to confirm say yes and press play
Press stop to exit.
Anonymous
  • Posted on Dec 19, 2009
SOURCE: Sony ICD-UX70/UX80 digital recorder...memory full problem
I solved the problem by connecting my Sony IC Recorder to the USB port on my McBook Pro computer and then emptying the trash can on the Mac computer. Visually (flashing red indicator light) and audibly (the recorder's sound that indicates something being erased), it was clear that mp3 files were finally, really being erased on the Sony recorder even though the recorder's own screen display had previously shown only empty folders and no files. Dragging files to the trash can doesn't really erase them unless you also empty the trash. All dragging to the trash can does is somehow mark the files in a way that, unfortunately, makes them invisible to Sony's file detection system.
Chuck in Omaha
Anonymous
  • 57 Answers
  • Posted on Feb 23, 2010
SOURCE: transfer digital recording to computer to make CD
As there is no USB port on this IC Recorder, you can connect the Headphone OUT of the IC Recorder to the LINE IN of the Computer. Then, use any Sound Recorder Software to capture the files. You can also use the Sound Recorder Software preinstalled in the Computer. After transferring the recordings to the Computer, you can use any CD Burning Software to burn the files to a CD.
Anonymous
  • 57 Answers
SOURCE: need to get owner manuel for sony voice recorder
You can download the Manual here: http://www.docs.sony.com/release/ICDB600.pdf
If you want to order the Hard Copy of the Manual, you can order it here(with in the US). https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=660685&searchOperation=modelSearch&searchText=ICDB600
I have lost my manual for my sony icd b500 didgital recorder is there a website containing this infomation
You can download and print the instruction manual in PDF format by clicking this link:
http://www.docs.sony.com/release/ICDB500.pdf
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
2helpful
Sony ICD-B500 recorder keeps flashing HOLD.
Look on the case. You'll see a button that slides. It takes it off of HOLD. HOLD mode is good to protect the recordings while the unit gets put in a pocket or purse.
There is no on/off button on the ICD-B500, so how do you turn it off?
As you say there is no on/off button on the unit. The display is on at all times. If you look at the instructions under the heading "3 Set the time", there is a tip that states this. Here's a link to the instructions:
http://www.fixya.com/support/p201161-sony_icd_b5_handheld_digital_voice/manual-16274
2helpful
Transfer digital recording to computer to make CD
Press stop to exit.
6helpful
3answers
MY SONY ICD-ST10 RECORDER IS STUCK WITH AN "ERR ACCESS" MESSAGE
I try this solution but it didn't work! I can select WHOLE but I can't select DELETE from the menu.
How can I do for restore the data storage or for delete all and formate the IC recorder?
ICD-B500 Recorder
Sony ICD-B500
If this device is in warrenty, you may not do this. If you do diassemble this B500, then you lose your warrenty. I'm a technician in belgium, so I do know this things.
friendly greetings,
werner
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
