Garden Logo
D
Diana fletcher Posted on Jun 02, 2019
How much oil does a craftman LT1500 riding lawnmower hold?thank you in advance.
5 Related Answers
Anonymous
  • 2559 Answers
  • Posted on May 01, 2009
SOURCE: turns over but does not start new spark plug in
First,make sure you are sitting in the seat as the seat has a safety switch under it that will prevent it from starting if noone is on it.
Check for spark,If no spark,Coil is not working.
Check for fuel at carb,If no fuel,check filter and Carb may needs cleaning or replaced.
If you have spark and fuel and it still won't start,It is a timing issue.
BAMOUT
Dennis Key
  • 2481 Answers
  • Posted on Mar 07, 2012
SOURCE: I can not find a manual for a 12 horse craftman riding lawnmower
Try www.managemylife.com And get free manual.
BAMOUT
Dennis Key
  • 2481 Answers
SOURCE: install deck for 12 horse craftman riding lawnmower
Go to www.managemylife.com and get a manual.
BAMOUT
Dennis Key
  • 2481 Answers
  • Posted on Mar 13, 2012
SOURCE: why is oil coming out of my muffler when i start my riding lawnmower 17 hp kholer engine craftman riding lawnmower
Check oil breather for being plug-up.
Andrew White
  • 2239 Answers
SOURCE: I GOT A SEARS CRAFTMAN riding lawnmower 17 hp 42 inch cut kohler engine.and when i start oil come out of my exhaust what causes that
Either over filled with oil, valve stem seals leaking, engine breather blocked, or the engine is badly worn.
Craftsman LT1500 Riding Lawn Mower. Does the LT1500 have the same engine as the LTS1500? Thanks
Question edited for full 'make model (what it is)'.
Question moved from Cars and Trucks.
Same engine
LT
Craftsman LT1500 Engine Specs
Briggs and Stratton Engine
Engine Model ..................... Briggs and Stratton 31C707
Engine Type ..................... 4-cycle single cylinder OHV vertical shaft air-cooled gasoline engine
Number of Cylinders ..................... 1
Displacement, cu.in (cc) ..................... 30.5 (500)
Cylinder Bore, in (mm) ..................... 3.56 (91.0)
Piston Stroke, in (mm) ..................... 3.06 (78.0)
https://www.google.com/search?q=craftsman+lt1500+engine
LTS
Craftsman LTS 1500 Engine
Engine Model .................. Briggs and Stratton 31C707
Engine Type .................. 4-cycle single cylinder OHV vertical shaft air-cooled gasoline engine
Number of Cylinders .................. 1
Displacement, cu.in (cc) .................. 30.5 (500)
Cylinder Bore, in (mm) .................. 3.56 (91.0)
Piston Stroke, in (mm) .................. 3.06 (78.0)
https://www.google.com/search?q=craftsman+LTS1500+engine
Does it have an oil filter that needs to be changed?
Yes, all riding lawn mowers have an oil filter. These are not small cycle motors which burn the oil with the gasoline. Please see your user manual or search for the advanced maintenance manual for your riding lawnmower online for specific details.
Jun 07, 2015 • Garden
Help line for craftman lawnmower
Could you check the model number again and provide the Brand?
Mar 13, 2012 • Garden
I have a craftman 6.0 21inch rear drive lawnmower it made a pop sound a will not start it has gas oil new sparkplug
Most of the time when a engine pops, or back fires, your valves are usually out of adjustment.
Jun 18, 2011 • Garden
2answers
I have a craftman GT5000 Lawnmower it quit charging were do i look for alternater?
The charging system is under the flywheel, but first check the 2 wires are connected at the side of the motor, they might be black and white at the conector.
White smoke from my Craftmans tractor,
Use the lawnmower's oil dipstick to determine whether the oil level is correct. Maintain the correct level of oil. If you've overfilled the oil, open the drain plug, and drain some of the oil into a waste container.
Dispose of any excess oil properly. Burning off excess oil is undesirable. It can foul the mower's spark plug, piston rings, and other engine components and contributes to air pollution.
If your mower's engine has not been overfilled with oil, but still is smoking, it may have stuck or worn piston rings or another maintenance problem.
If it has sat over the winter, and didnt have stabilizer in it - it may be bad gas too. Drain it out, and put in fresh.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Top Garden Experts
Jay Finke
Jay Finke
john h
